Digital Voice for Business is a flexible, cost-effective, and modern way to handle phone calls for both personal and business use. It’s sometimes known as Voice over Internet Protocol (VoIP).
What makes Digital Voice for Business different?
- It's internet-based. Instead of using traditional physical phone lines for calls, Digital Voice for Business converts your voice into digital data and sends it over the internet.
- It's hosted in the cloud. The system is managed by BT in the cloud, so you don’t need to maintain any hardware on site.
How it can benefit your business
- It can help you save on costs. It’s usually cheaper because it removes the need for expensive phone lines and hardware.
- It’s flexible. You can make and receive calls from anywhere with an internet connection, using devices like smartphones and laptops, or traditional phones with adapters.
- It’s scalable. You can easily add or remove users and features as your needs change, without significant hardware changes.
Key business features of Digital Voice for Business
- Advanced calling - includes things like call forwarding, voicemail, call recording, Auto Attendant, Hunt groups, and more.
- Integration - Digital Voice can integrate with other communication tools like video conferencing and instant messaging.
Get set up quickly
Once you’ve purchased Digital Voice for Business and your order is confirmed, you will soon get access to our Digital Voice for Business portal where you can begin setting up your new service. From the portal, you can start doing things like creating users, setting up call flows, and applying time schedules to ensure your calls are routed to the correct members of your team.
If you have less than 8 connections, you should be able to get set up within 30 minutes, without extensive technical support.
