Thanks for choosing BT PC Security.
We take your online security very seriously, follow the steps below to successfully install your new software.
1. Log into My BT Business account
Log in using our primary username and password. These were sent to you in your welcome emails.
2. Download and install BT PC Security
- Go to //www.bt.com/business/activatesecurity and press enter.
- Select the download button.
- Make a note of the license key as you might need it later.
- Read and accept the End User Licence Agreement.
- Select the Run button, BT PC Security installation will automatically remove many existing software security packages (after asking for your permission). When the removal is complete, you'll be asked to restart your computer.
- Select continue when completed.
- Select the reboot button. Your computer will resume and complete the installation.
- You'll know when BT PC Security is fully installed and protecting your PC when you see the McAfee icon in your system tray:
