You can record a personalised Auto Attendant message using the Voice Portal, or you can upload a pre-recorded greeting.
There are currently two versions of the Cloud Voice Business Portal.
If you were set up on Cloud Voice before the 16 May 2022, you’ll be using the original version. If you were set up after this date, you’ll be using the newer version of Cloud Voice accessed via My Account.
To display the right help content, select the image that matches your login screen.
