Setting up your Complete Wi-Fi Plus is straightforward. The quickest and easiest way is by using the BT Business app.
Not got the app? You can still set up your Wi-Fi Plus without it.
1. Pair your Wi-Fi Plus with your Smart Hub 3
Make sure your hub is plugged in and switched on. Attach one end of the Ethernet cable (yellow ends) into the back of your Wi-Fi Plus and the other one in to the yellow Ethernet ports on your hub.
2. Switch your Wi-Fi Plus on
Plug your Wi-Fi Plus in at the wall and press the power button.
3. Wait for the pairing to finish
The light on your Wi-Fi Plus will change colours. After a couple of minutes, the light should turn solid indigo which means that your Wi-Fi Plus is paired to your new hub.
4. Remove the Ethernet cable and unplug the power from your Wi-Fi Plus
Unplug the Ethernet cable from both devices. The light on your Wi-Fi Plus will turn red. Wait until it turns solid indigo again and then unplug the power cable.
5. Pick a location for your Wi-Fi Plus
Move your Wi-Fi Plus to an area between your hub and where your signal needs a boost. When you think you've found it, plug in your Wi-Fi Plus and switch it on.
6. Wait for a connection
Wait for the light to turn solid indigo. If it turns orange, you might need to find a new location.
