Skip to main content
Set up CRM Integrator and CRM Lite for BT Cloud Voice | BT Business
not-authored-help-and-support
Set up CRM Integrator and CRM Lite for Cloud Voice
Looking to integrate Windows Desktop customer relationship management (CRM) applications into BT Cloud Voice? You’ll need CRM Integrator or CRM Lite.
CRM Integrator works with a wide range of CRM systems.
CRM Lite only works with Microsoft Outlook, Google Contacts and Lotus Notes, plus light integration to Skype for Business.
To find out more about CRM Integrator and CRM Lite, and learn how to set them up with BT Cloud Voice, take a look at our user guide today.
BT Cloud Voice user guide for CRM Integrator and CRM Lite (PDF, 296K)
Did this help?
Additional support
