Skip to main content
MN3300 Maintenance Commands | BT Business
not-authored-help-and-support
Below is a list of maintenance commands for your MN3300:
Note: only use if you understand what you're doing or if instructed to do so by the BT Mitel customer support desk.
ALARMS
BACKGROUND
BACKGROUND ON <diagnostic type>
BACKGROUND OFF <diagnostic type>
BACKGROUND STATUS <diagnostic type>
ARPSHOW
BAUD
BAUD <new baud rate> <SC5550IP input or output system port name>
BLF ALLOW LOGS
BLF FILTER LOGS
BLF LOGS STATUS
BLF REFRESH
BLF REFRESH CEID <CEID INDEX>
BLF REFRESH CEID ALL
BRI
BRI CONFIG MMC ALL
BRI CONFIG MMC <number>
BUSY
BUSY <cabinet>
BUSY EXTENSION <extension number>
BUSY RESET <number>
BUSY TRUNK GROUP <group number>
BUSY XNET ALL
BUSY XNET ALL IP
BUSY XNET ALL ISDN
BUSY XNET ICP <ICP number>
BUSY XNET ICP <ICP number> IP
BUSY XNET ICP <ICP number> ISDN
BWM STATISTICS RESET
CANCEL PRINT
CANCEL PRINT ALL
CANCEL PRINT ALL /PORT <port name>
CANCEL PRINT /PORT <port name>
CANCEL PRINT <job number>
CANCEL PRINT <job number> /PORT <port name>
CATALOG INFO
CATALOG INFO <path name>
CATALOG INFO <path name> FULL
CATALOG INFO <path name> SUBCATALOGS
CATALOG INFO <path name> TOTAL
CBM
CBM DISABLE LOG
CBM ENABLE LOG
CCS
CCS RESET DASS2
CCS RESET DPNSS ROUTE_OPT_STATISTICS
CCS SHOW DASS2 FEATURE_STATUS
CCS SHOW DASS2 ROUTE_OPT_STATISTICS
CCS SHOW DPNSS
CCS TRACE CLEAR CONTEXT
CCS TRACE DISABLE
CCS TRACE ENABLE
CCS TRACE ENABLE CONTINUOUS
CCS TRACE SET CONTEXT <location ID>
CCS TRACE SET CONTEXT VIRTUAL <location ID>
CCS TRACE SET CONTEXT XNET
CCS TRACE SHOW CONTEXT
CCS TRACE SHOW OUTPUT
CHANGE PASSWORD (MLPP)
CONGESTION
CP SERVICE
CP SERVICE DAY
CP SERVICE NIGHT1
CP SERVICE NIGHT2
CRSQUERY
DBMS
DBMS CHECK BRIEF
DBMS CHECK FULL
DBMS CHECK KILL
DBMS CHECK ON
DBMS CHECK OFF
DBMS CHECK TIME <hour>
DBMS CLIENT
DBMS FLAG OFF
DBMS SAVE
DBMS STATUS
DBTAB
DBTAB <table id>
DBTAB <table id> <record id>
DGT TRACE
DIGITAL TRUNK STATISTICS
DTSTAT CLEAR <unit> <shelf> <slot> <hybrid>
DTSTAT READ <unit> <shelf> <slot> <hybrid>
DTSTAT READ <unit> <shelf> <slot> <hybrid> LAST <number of hours>
DISPLAY ASU INFO
DTSTAT
DUMPDSPBOOTINFO
EMBEDDED DIGITAL TRUNK DIAGNOSTICS
EDT
EDT Cancel Handoff
EDT Courtesy Handoff
EDT Delete
EDT Disable
EDT Enable
EDT Force Failback
EDT Force Failover
EDT Help
EDT Show
EDT Show Resiliency
EDT Trace
FAX LOG DISABLE
FAX LOG ENABLE
FIRMWARE
FIRMWARE PLID <unit> <shelf>
FIRMWARE PLID <unit> <shelf> <slot>
FIRMWARE PLID <unit> <shelf> <slot> <circuit>
FIRMWARE PLID <unit> <shelf> <slot> <circuit> <channel>
FIRMWARE KILL ALL
FIRMWARE KILL PLID <unit> <shelf>
FIRMWARE KILL PLID <unit> <shelf> <slot>
FIRMWARE KILL PLID <unit> <shelf> <slot> <circuit>
FIRMWARE KILL PLID <unit> <shelf> <slot> <circuit> <channel>
FMAUSERCONFG
FMAUSERCONFIG GET
FMAUSERCONFIG SET ARFAP ENABLED
FMAUSERCONFIG SET ARFAP DISABLED
FMAUSERCONFIG SET POLLING ENABLED
FMAUSERCONFIG SET POLLING DISABLED
FORMPRINT
FORMPRINT <form name>
FORMPRINT <form name> /ALL
FORMPRINT <form name> /ALL /COPIES n
FORMPRINT <form name> /ALL /PORT <port name>
FORMPRINT <form name> /ALL /PORT <port name> /COPIES n
FORMPRINT <form name> /COPIES n
FORMPRINT <form name> /COPIES n /PORT <port name>
FORMPRINT <form name> /INSTANCE n
FORMPRINT <form name> /INSTANCE n /COPIES n
FORMPRINT <form name> /INSTANCE n /PORT <port name>
FORMPRINT <form name> /INSTANCE n /PORT <port name>COPIES n
FORMPRINT <form name> /PORT <port name>
FORMPRINT /KILL
HANDOFFSERVICE SHELL COMMANDS
hsHelp
hsShowIcps
hsShowSets
hsHandoff
hsHandback
hsPushback
hsDebug
hsTrace
HISTORY
HISTORY DELETE [EXT yyyy] | ALL
HISTORY DELETE ALL
HST
HST COURTESY HANDOFF
HST CANCEL HANDOFF
HST STATUS HANDOFF
HTMLAPPUPGRADE
INET STAT SHOW
IPN DNS
IPN DNS Del
IPN DNS NSLookup
IPN DNS Show
LAYER 2
L2 PoEStatus
L2 Stat Maclist
L2 Stat Port
L2 Stat Spanning Tree
L2 Stat Switch
Note: Layer 2 commands are not applicable to MCD for Industry Standard Servers (ISS) since Layer 2 switching is performed by an external Layer 2 switch.
LANGUAGE ADD
LANGUAGE ADD <language> SETS DEFAULT FROM *.LANGSEL
LANGUAGE ADD <language> SETS AUX1 FROM *.LANGSEL
LANGUAGE ADD <language> SETS AUX2 FROM *.LANGSEL
LANGUAGE DISPLAY
LANGUAGE DISPLAY SETS DEFAULT
LANGUAGE DISPLAY SETS AUX1
LANGUAGE DISPLAY SETS AUX2
LANGUAGE SELECT
LANGUAGE SELECT <language> SETS DEFAULT FROM *.LANGSEL
LANGUAGE SELECT <language> SETS AUX1 FROM *.LANGSEL
LANGUAGE SELECT <language> SETS AUX2 FROM *.LANGSEL
LOAD
LOAD <unit/module>
LOAD IPDevice <1,2...700>
LOAD IPDevice <1> TO <700>
LOAD CONTROLLER
LOCATE
LOCATE AGENT <agent identifier>
LOCATE ALL FREE DN <dnmin> TO <dnmax>
LOCATE ALL FREE PLID <card type> <unit>
LOCATE ALL FREE PLID <card type> <unit> <shelf>
LOCATE ALL FREE PLID <card type> <unit> <shelf> <slot>
LOCATE ALL FREE PLID <card type> <unit> <shelf> <slot> <circuit>
LOCATE ALL FREE PLID <card type> <unitmin> TO <unitmax>
LOCATE EXTENSION <extension number>
LOCATE FEATURE EXT <extension number>
LOCATE FEATURE HUNT_GROUP <number>
LOCATE FEATURE PLID <unit> <shelf> <slot>
LOCATE FEATURE PLID <unit> <shelf> <slot> <circuit>
LOCATE FIRST FREE DN <dnmin> TO <dnmax>
LOCATE FIRST FREE PLID <card type> <unit>
LOCATE FIRST FREE PLID <card type> <unit> <shelf>
LOCATE FIRST FREE PLID <card type> <unit> <shelf> <slot>
LOCATE FIRST FREE PLID <card type> <unit> <shelf> <slot> <circuit>
LOCATE FIRST FREE PLID <card type> <unitmin> TO <unitmax>
LOCATE GROUP_REPORTING_NUM <number>
LOCATE HOT_DESK_USER ALL
LOCATE HOT_DESK_USER TARGETS
LOCATE HOT_DESK_USER ACTIVE
LOCATE HOT_DESK_USER INACTIVE
LOCATE IP_LICENSE DEVICE_ONLY
LOCATE IP_LICENSE PENDING_USER
LOCATE IP_LICENSE SUMMARY
LOCATE NUMBER <number>
LOCATE MOBILE_DN ALL
LOCATE MOBILE_DN TARGETS
LOCATE MOBILE_DN ACTIVE
LOCATE MOBILE_DN INACTIVE
LOCATE PATH_REPORTING_NUM <number>
LOCATE PLID <unit> <shelf> <slot>
LOCATE PLID <unit> <shelf> <slot> <circuit>
LOCATE PLID <unit> <shelf> <slot> <circuit> <channel>
LOCATE REMOTE_DN <number>
LOCATE TENANT
LOCATE TENANT <number>
LOCATE TRUNK <trunk number>
LOGSYS
LOGSYS ATTRIBUTES <logname>
LOGSYS CANCEL P <logname>
LOGSYS PRINT <logname>
LOGSYS PRINT <logname> ALL
LOGSYS READ <logname> ALL
LOGSYS READ <logname> ALL MATCH <string>
LOGSYS READ <logname> INTO <filename> ALL
LOGSYS READ <logname> INTO <filename> ALL MATCH X
LOGSYS READ <logname> NEWEST X
LOGSYS READ <logname> NEWEST X MATCH <string>
LOGSYS READ <logname> INTO <filename> NEWEST X
LOGSYS READ <logname> INTO <filename> NEWEST X MATCH X
LOGSYS READ <logname> OLDEST X
LOGSYS READ <logname> INTO <filename> OLDEST X
LOGSYS READ <logname> INTO <filename> OLDEST X MATCH X
LOGSYS SIZE <logname> RAM <number of bytes>
LOGSYS SIZE <logname> FILE <entry count>
MESSAGE
MESSAGE REMOTE
MESSAGE SUBSYSTEM
MIGRATION PRECHECK
MIGRATION STATUS
MIGRATION SUMMARY
MOVE
MOVE ADD <Lastname, Firstname> TO <extension number>
MOVE DELETE <Lastname, Firstname> FROM <extension number>
MOVE RENUMBER <old number > TO <new number>
MOVE SWAP <first number > WITH <second number>
MOVE USER <first number> TO <second number>
NETSYNC
NETSYNC SETSOURCE <source number>
NETSYNC SETSOURCE AUTO
NETSYNC SETSOURCE FREERUN
NETSYNC STATE
NETSYNC SUMMARY <number>
NETSYNC SUMMARY <number> LAST <number of hours>
PCM
PCM STATUS RX <link>
PCM STATUS TX <link>
PCM TOTALS
PENDING CHANGES
PENDING CHANGES DELETE
PENDING CHANGES DISPLAY ALL
PENDING CHANGES DISPLAY COUNT
PENDING CHANGES DISPLAY NEW <number>
PENDING CHANGES GENERATE <string> BLANK
PENDING CHANGES GENERATE <string> <string>
PENDING CHANGES GENERATE BLANK BLANK
PENDING CHANGES GENERATE BLANK <string>
PING
PMS
PMS TRACE DISABLE
PMS TRACE ENABLE
PMS STATE
PORT DISABLE (MLPP)
PORT ENABLE (MLPP)
PROGRAMMED FAILBACK
PROGRAMMED REBOOT
PROGRAMMED REBOOT COURTESY ON
PROGRAMMED REBOOT COURTESY OFF
PROGRAMMED REBOOT DISPLAY
PROGRAMMED REBOOT RESOURCE RECOVERY ON
PROGRAMMED REBOOT RESOURCE RECOVERY OFF
PROGRAMMED REBOOT RESOURCE RECOVERY <hh:mm:ss>
PROGRAMMED REBOOT SCHEDULE ON
PROGRAMMED REBOOT SCHEDULE OFF
PROGRAMMED REBOOT SCHEDULE <DAILY> <hh:mm:ss>
PROGRAMMED REBOOT SCHEDULE <day-of-week> <hh:mm:ss>
PROGRAMMED REBOOT SCHEDULE MONTHLY <week # [1-4]> <day-of-week> <hh:mm:ss>
PROGRAMMED REBOOT SCHEDULE INTERVAL <interval in weeks [1-52]> <MMM> <day-of-month> <hh:mm:ss>
PROGRAMMED SERVICE
PROGRAMMED SERVICE SCHEDULE NIGHT1 DAILY <hh:mm:ss>
PROGRAMMED SERVICE SCHEDULE NIGHT1 ON/OFF
PROGRAMMED SERVICE SCHEDULE NIGHT2 DAILY <hh:mm:ss>
PROGRAMMED SERVICE SCHEDULE NIGHT2 ON/OFF
PROGRAMMED SERVICE SCHEDULE DAY DAILY <hh:mm:ss>
PROGRAMMED SERVICE SCHEDULE DAY ON/OFF
PROGRAMMED SERVICE SCHEDULE ON/OFF
PROGRAMMED SERVICE DISPLAY
PROM
PROM <unit> <shelf> <slot>
PROCESS STATUS
READDATETIME
READDATETIME
REMOVE COURTESY DOWN
REMOVE COURTESY DOWN <unit> <shelf> <slot> <circuit>
REMOVE COURTESY DOWN EXTENSION <extension number>
RESET
RESET SYSTEM
RESET APC
RESET PASSWORD (MLPP)
RESET USERNAME (MLPP)
RESOURCES
RESOURCE <unit> <shelf> <slot> <circuit or hybrid>
RESOURCE <unit> <shelf> <slot> <circuit or hybrid> <channel>
RESOURCE XNET <trunk>
RESTART CALLSERVER
RETURN TO SERVICE
RTS <unit> <shelf> <slot>
RTS <unit> <shelf> <slot> <circuit or hybrid>
RTS <unit> <shelf> <slot> <circuit or hybrid> <channel>
RTS EXTENSION <extension number>
RTS TRUNK GROUP <group number>
RTS XNET ALL
RTS XNET ALL IP
RTS XNET ALL ISDN
RTS XNET ICP <ICP number>
RTS XNET ICP <ICP number> IP
RTS XNET ICP <ICP number> ISDN
RMESSAGE
RMESS VERIFY PBX <pbx number> LAN
RMESS VERIFY PBX <pbx number> PPP
ROUTESHOW
SET THRESHOLDS
SET THRESHOLDS < alarm category> <minor threshold> <major threshold> <critical threshold>
SHOW
SHOW FAULTS ALARMS
SHOW FAULTS <alarm category>
SHOW PRINT
SHOW PRINT <printer name>
SHOW PRINT ALL
SHOW STATUS <alarm category>
SHOW STATUS ALARMS
SHOW STATUS ALARMS ALL
SHOWDSPSTATUS
SHUTDOWN
SIP
BUSY PEER < PEER_NAME>
BUSY FORCE PEER < PEER_NAME>
RTS PEER < PEER_NAME>
LINK STATE PEER < PEER_NAME>
LINK STATE ALL
LINK STATUS
SHOW ACTIVE ALL
SHOW ACTIVE PEER <PEER_NAME>
SHOW ACTIVE PROFILE <PROFILE_NAME>
SNMP COMMON STATS SUMMARY
SNMP OTHER COMMON STATS
SNMP STATS METHOD < METHOD_NAME>
SNMP TIMERS CONFIGURATION
SNMP COMMON CONFIGURATION
SNMP PORT CONFIGURATION
SNMP SUPPORTED METHODS
STATS PROFILE <PROFILE_NAME>
STATS ALL
SIP REGISTRAR CONFIG
SIP REGISTRAR STATS
SIP REGISTRAR CONTACTS ALL
SIP REGISTRAR CONTACTS <USER_NAME>
SIP MWI STATS
SIP MWI STATS CLEAR
SIP MWI SUBSCRIBER INFO ALL
SIP MWI SUBSCRIBER INFO <CONTACT NAME>
SIP URI TRANS DEBUGON
SIP URI TRANS DEBUGOFF
SIP URI TRANS LIST
SIP URI TRANS SORTURI
SIP UIR TRANS SORTNUM
SLOTALLINFO
STATE
STATE <unit>
STATE <unit> <shelf>
STATE <unit> <shelf> <slot>
STATE <unit> <shelf> <slot> <circuit or hybrid>
STATE <unit> <shelf> <slot> <circuit or hybrid> <channel>
STATE EXTENSION <extension number>
STATE MLS <unit> <shelf> <slot> <circuit or hybrid>
STATE TRUNK GROUP <group number>
STATE TRUNK GROUP <group number> TRAFFIC
STATE TRUNK GROUP <group number> VIRTUAL
STATE TRUNK GROUP <group number> ALL
STATE XNET ICP <ICP number>
STATE XNET ALL
STATE XNET ALL IP
STATE XNET ALL ISDN
STATE XNET TRUNK <trunk number>
STATE XNET LINK <link number>
SWAP
Note: the SWAP command is not applicable to MCD for ISS.
SYSTEM TOTALS
TEST
TEST <cabinet> <shelf> <slot>
TEST <cabinet> <shelf> <slot> SEIZE
TEST <cabinet> <shelf> <slot> <circuit>
TEST <cabinet> <shelf> <slot> <circuit> CONTINUOUS
TEST <cabinet> <shelf> <slot> <circuit> SEIZE
TEST <cabinet> <shelf> <slot> <circuit> UNTIL FAIL
TEST <cabinet> <shelf> <slot> <hybrid>
TEST <cabinet> <shelf> <slot> <hybrid> <channel>
TEST <cabinet> <shelf> <slot> <hybrid> <channel> CONTINUOUS
TEST EXTENSION <extension number>
TEST TRUNK GROUP <group number> TRAFFIC
TEST UNTIL FAIL
TRACERT
RTC <ip address> /HOPS n /WAIT n
IPSET <ip address> to <ip address> /HOPS n /WAIT n
TRAFFIC
TRAFFIC DELETE <MMM - dd hh : mm>
TRAFFIC FILES
TRAFFIC PRINT <MMM - dd hh : mm>
TRAFFIC STATUS
TRAFFIC STOP
TYPE
TYPE *.DR.LOGFILE_1
UPGRADEBOOTROM
UPGRADEBOOTROM RTC
UPGRADEBOOTROM E2T
UPGRADEBOOTROM ALL
UPTIME
VERSION
VOICE MAIL
WHERE
WRITEDATETIME
WRITEDATETIME <year> <month> <day> <day-of-week> <hour> <minute> <second>
Did this help?
Additional support
