Yes, follow the steps below to find it:
- Log in to your system as far as the first screen.
If you don't know how to do this please see How do I connect to my MN3300 system? - When you're logged in and at the first screen click System Admin Tool.
- Select Help. This can be found top right of the screen.
A popup window will open with a page that is relevant to the area you're in. - When you've finished simply click X in the top right corner to close the Help page.
