Skip to main content
How do I customise an Auto Attendant greeting on my BT Versatility? | BT Business
not-authored-help-and-support
Personalised Auto Attendant messages can be recorded on the system.
To customise the Auto attendant message
  1. From the Programming Extension, press the PROGRAM Key.
  2. Press the Scroll Down Key until System programming is displayed.
  3. Select System programming.
  4. Enter the System Programming Password and select System.
  5. Select Change greetings
  6. Select Auto attendant day or Auto attendant night to record the Day Service and Night Service greetings respectively.
  7. Select Record greeting.
  8. When prompted, speak to record the new greeting
  9. Press the Hands-free Key to finish programming.
The greeting is recorded on the handset; however, professional recording agencies should be able to supply equipment that will allow digital recordings to be made from a computer through the handset connection.
BT does not supply this equipment.
Did this help?
Additional support
