Skip to main content
Using Auto Attendant on BT Versatility | BT Business
not-authored-help-and-support
Using Auto Attendant on BT Versatility to automatically answer calls
You can automatically answer calls on BT Versatility using Auto Attendant.
You can use Auto Attendant if the system is equipped with a Voice Module. If you’re not sure if your BT Versatility system is equipped with a Voice Module, check if your system has voicemail.
The Auto Attendant feature can be used anytime you want your calls to be answered automatically by the system and greeted with a recorded announcement. The time before the call is answered is programmable. Find out how to program Auto attendant below.
For more information on Voicemail see page 67 and for Auto Attendant see page 76 of the BT Versatility Owner’s Manual:
BT Versatility Owners Manual (PDF, 665KB)
You’ll need Adobe Reader to view PDF documents.
How to program which lines are answered by Auto Attendant
If you want to program which lines are to be answered by the Auto Attendant:
  1. From the Programming Extension, press the PROGRAM Key.
  2. Press the Scroll Down Key until System programming is displayed.
  3. Select System programming.
  4. Enter the System Programming Password (1111 in default) and select Lines.
  5. Press the Scroll Down Key until Incoming ringing is displayed.
  6. Select the Line or Access that is to be programmed.
  7. Select Day, Night, or Day and Night.
  8. Select Auto attendant.
  9. Press the Hands-free Key to finish programming.
You might also want to change the Auto attendant greeting.
Customising an Auto Attendant greeting on BT Versatility
Personalised Auto Attendant messages can be recorded on the system.
To customise the Auto attendant message:
  2. Press the Scroll Down Key until ‘System programming’ is displayed.
  3. Select ‘System programming’.
  4. Enter the System Programming Password and select ‘System’.
  5. Select ‘Change greetings’.
  6. Select ‘Auto attendant day’ or ‘Auto attendant night’ to record the ‘Day Service’ and ‘Night Service’ greetings respectively.
  7. Select ‘Record greeting’.
  8. When prompted, speak to record the new greeting.
The greeting is recorded on the handset, but professional recording agencies should be able to supply equipment that’ll allow digital recordings to be made from a computer through the handset connection.
BT does not supply this equipment.
Can Directory Message be used when I’m using the BT Versatility Auto Attendant?
The Directory Message is there as an additional greeting.
For example your main Auto Attendant greeting might say:
  • For sales dial 1.
  • For accounts dial 2 - if you know the extension number of the person you require then dial now.
  • Alternatively, if you would like to listen to the company Directory dial # now.
  • If you require assistance, please wait or dial 0.
Dialling # will take the caller to the Directory Message.
This could be recorded as follows:
  • For Jim Smith dial 20.
  • For Joe Bloggs dial 21.
  • For Sarah Montague dial 22 etc.
The Directory message allows you to give the caller more information, but the caller chooses if they want to hear that extra information by dialling #.
For full details go to page 76 of the BT Versatility Owner’s Manual, below:
Did this help?
Additional support
