Personalised Auto Attendant messages can be recorded on the system.
To customise the Auto Attendant message from the Programming Extension:
- From the Programming Extension, press the Program Key.
 - Select System Program.
 - Enter the System Programming Password.
 - Select Change Greetings.
 - Select either Auto atten day to record the Day Service greeting or Auto atten night to record the Night Service greeting.
 - Select Record greeting.
 - When prompted, speak into the handset to record the new greeting and press # when finished.
 - Replace the handset.
