The steps below will take you through backing up your IP Office telephone system -
- Login to IP Office Manager
- Go to File > Save configuration as
- Select a location, this is where you want the file to be saved and make sure the file type is a .CFG format
- Press Save
How to restore your IP Office system
- Go to File > Offline > Open file
- Find the back up file, it will then open in IP Office Manager in an offline mode
- To restore the file you've just selected in step 3 select File > Offline > Send config
- Tick the box next to your IP Office and press Ok
- It will ask you to enter your username and password
- Next, reboot your system, select File > Save configuration and then Immediate
