Before you start you may want to print out this long list of instructions.
1. First create a Dummy User
Right click on User and select New
Enter a User Name e.g. Call Forward
Enter a dummy Extension Number XXXX ( Note - This must be unique)
Click Ok to save
A pop up box will appear. Select None and click Ok
Click on the Voicemail tab and Uncheck Voicemail On
Click on Telephony tab > Supervisor Settings
Ensure Inhibit Off-Switch Forward/Transfer is Unchecked
Click on the Forwarding tab and tick the following:
Forward Unconditional
Forward Hunt Group Calls
Forward Internal Calls -
Enter the telephone number you wish your calls to go to in the Forward Number field. Prefix the number with a 9 and click Ok
Click the User tab and set the User Rights View to Working Hours User Rights
Set the Working Hours User Rights to Generic
Click Ok and select Save Configuration
2. Create a Hunt Group
Right click on Hunt Group and click New
Enter a Hunt Group Name (e.g. CFWD)
Enter an Extension Number YYYY ( Note - This must be unique)
Set the Ring Mode Hunt Group to either Sequential or Rotary
Add the new dummy user (Call Forward) XXXX to the Hunt Group (CFWD) YYYY
Under the User List click on the Edit button
Click on the Dummy Extension to highlight it
Click the Append button to add the Extension to this Hunt Group
Click Ok -
3. Click on the System Tab
- Click on Telephony then click Telephony
- Ensure Inhibit Off-Switch Forward/Transfer is Unchecked
4. Add a new System Short Code
Note - The short code must be unique so you must check the code doesn't already exist. Select System Short Code at the left hand side and check the code 9N is not in the list.
Right click on System Short Code and click New then enter the following details below:
Short Code: 9N
Feature: Dial
Telephone Number: N
Line Group: 0 or relevant group -
5. Program Fall Back On Main Hunt Group
- Click on Hunt Group
- Select the Main Hunt Group you want to forward to the external number
- Click on the Voicemail tab and ensure Voicemail box is Un-Ticked
- Click the Fallback tab and Set Out Of Service Fallback to new the Hunt Group (CFWD)
- Click Ok and select Save Configuration
6. Setting call forward using either a Short Code or by programming a button on your phone
System Short Code
Manually call forward the main hunt group using a Short Code
Right click on Short Code and select New and enter the following details:
Code: *21*
Feature: Set Hunt Group Out of Service
Telephone Number (number of the Hunt Group you wish to take out of Service)
Line Group: 0Click Ok
Manually cancel the call forward from the main hunt group using a Short Code
Code: *21#
Feature: Clear Hunt group out of Service
Telephone Number (number of the Hunt Group that you want to clear the Out of Service)
Line Group: 0Click Ok and select Save Configuration
Button Programing
To program a button on a specific users extension:
Left click on User
Select the Extension Number of the user who will have the button on their phone
Click on Button Programming
Select a Button number and then click Edit and enter the details as below:
Label: Name the button
Action: Set Hunt group Out of Service
(Click on 3 dots > Select Advanced > Select Set > Select Hunt Group Out of Service)
Action Data: number of Hunt group that you want to clear the Out of Service -
Click Ok and select Save Configuration then Merge
