You'll need to access your mailbox either by a system shortcode or using the Visual Voice button on the Avaya telephone which then depends on how it's configured.
A greeting must be longer than 3 seconds. The maximum length of a greeting is 120 seconds by default.
Changing the mailbox greeting using a system shortcode
A system short code may be *17, *715 or another code with a * or # then a 3 digit code. This all depends on how this was configured on your Avaya IP Office telephone system.
 Caution: Before re-recording any mailbox greeting once in your mailbox play your current recording first to ensure this is the message you want to change.
 If you're prompted, enter your mailbox number followed by the # key. If you're not prompted continue with the next step.
Enter your secure mailbox password followed by the # key.
Once you're in your mailbox, press 3 to access the change 'Mailbox Greeting' menu. You now have the following options: - Always listen to your current mailbox greeting: press 1
 If this is the correct message you want to change continue with the next step, if not disconnect from the mailbox.
- Record a new greeting: press 2 (speak after the tone).
 Note: A long (approximately 10 seconds) period of silence will disconnect you from voicemail.
- To play back and listen to your new greeting, press 1
You now have 2 choices to save your new greeting either to allow voicemail messages to be left in your mailbox or just play a greeting only. Save a new greeting and allow voicemail messages press 3 (if you hang up before pressing 3 the new greeting won't save). Or Save a new greeting as a loop (i.e. as an announcement only) press 4. Note: When selecting this option, you can only change the greeting back to a normal greeting by recording a new greeting.
Changing the mailbox greeting using the Visual Voice button
This will depend on how your Avaya IP Office is configured.
Press the Message button and select the mailbox. - Enter your voicemail secure password and then press Done.
The 'Visual Voice' menu is displayed.
Use the up and down cursor keys to select Greeting and press Select.
Use the soft keys to listen to and record your mailbox greeting: Caution: Before re-recording any mailbox greeting once in your mailbox, play your current recording first to ensure this is the message you want to change. If this is the correct message you want to change, then continue to re-record the greeting, if it isn't the correct greeting press the Cancel option to return to the main visual voice menu. - Listen - Always listen to the current greeting or the new greeting just recorded.
- Stop - Record a new greeting. Note that the greeting must be at least three seconds long or the voicemail system discards it.
- Submit - Submit the new recording as your mailbox greeting.
- Delete - Delete your mailbox greeting. Your mailbox returns to using the system’s default mailbox greeting.
- Cancel - Return to the main visual voice menu.
