Skip to main content
Cancelling an Extension Call forward or Twinning feature on Avaya IP Office | BT Business
not-authored-help-and-support
If an Extension user has programmed a call forward or twinning feature on their phone to send all their direct dial calls to another destination, it is easy to cancel this feature.
On the phone, dial *00
You will hear 2 beeps to confirm this feature is cancelled.
The Status reminder will disappear from the display on the Avaya phones.
Did this help?
Additional support
