Skip to main content
The number I'm calling is permanently engaged. Could this be due to a fault? | BT Business
not-authored-help-and-support
If you're reasonably certain that the party you're calling should be answering the phone then a line fault may be the cause. Check your own line first to ensure it's working properly before reporting a fault on another person's line.
Did this help?
Additional support
