Skip to main content
Avaya IP Office Hunt Group | BT Business
not-authored-help-and-support
Hunt Group on IP Office
Find out how to change or record an IP Office Hunt Group mailbox greeting, add or remove extension users and set and record queuing announcements.
Change or record an IP office Hunt Group mailbox greeting
To change or record a Hunt Group mailbox greeting:
  1. Dial *17 from any extension.
  2. Enter the Hunt Group mailbox number.
  3. If you’re prompted to enter a password, enter the four digit password and then press the # key.
  4. Press digit 3 on your keypad.
The following options are available:
  1. Listen to greeting: Press 1 (listen to latest saved recording)
  2. Record a new greeting: Press 2 (speak after the tone)
  3. To end the recording: Press 2
  4. Save a new greeting: Press 3(if you hang up before pressing 3 the message won’t save)
  5. Save a new greeting as a loop (as an announcement only): Press 4
Add or remove an extension user from a Hunt Group
If you need to add or remove an extension user from a Hunt Group using the IP Office Manager:
Adding an extension user to a Hunt Group
Removing an extension user from a Hunt Group
Hunt Group queuing announcements
How to record a Hunt Group queuing announcement
How to setup a Hunt Group queuing announcement
Did this help?
Additional support
