Skip to main content
Using the Digital Voice for Business portal
not-authored-help-and-support
The Digital Voice for Business portal is where your users can manage their individual handsets, and specific features such as voicemail.
It's also where your administrators can manage all employee handsets and business-wide features, such as setting up Hunt groups, Auto Attendants, and call forwarding across your business.
Accessing the Digital Voice for Business portal
You can access the Digital Voice for Business portal from any device, anytime, anywhere - as long as you're connected to the internet. To log in to the portal, you’ll need the username and password that you entered when setting up your account.
Log in to the Digital Voice for Business portal
Digital Voice for Business portal features
Here are guides on how to use some of the main features within the portal:
How to get more help
Once you’re logged into the portal, you can get even more help and support.
Just locate and tap the Assist me button which is available on every page within the portal.
When you tap on it, you’ll find detailed guides on how to use various Digital Voice features.
You can find more step-by-step guides on features and setting up your Digital Voice for Business service in our Digital Voice for Business frequently asked questions page.
Did this help?
Additional support
