It's our DIY website builder that you can access through your BT Business Apps. Using a setup wizard, you can quickly and easily build a professional website for your business.
We no longer sell website builder, but it’s still available to customers who’ve already purchased the service.
Need a hand using Website Builder from BT? We've loads of videos, hints and tips available to help you.
Just login to BT Business Apps and select Website Builder from your My Apps page. Once you're in Website Builder select Help (bottom right corner).
You can also go to our partner Website Builder Support area
If you can't find an answer to your question, fill out this form and we'll get back to you.
