Online Presence Builder is no longer available to buy. If you already have this service, you can continue to use it.
The Online Presence Builder (OPB) is our web creator tool which enables you to create a customised website.
It's an intuitive tool with designs created to help you take your business to the next level online. Using simple 'drag and drop' elements, you can easily create and publish a website, optimised for mobile, in a few clicks.
It works with the following browsers:
- Firefox
- Internet Explorer
- Safari
- Chrome
You don't need any design experience and you can choose from engaging, SEO-friendly website themes that automatically look great on desktop, mobile and tablet devices. You can add photo galleries, videos, buttons, Facebook widgets, contact forms and appointment scheduling, Google maps, tables and much more.
You can access the Online Presence Builder (OPB) from the BT Website Centre in your online account.
How do I get started?
- Log in to the BT Website Centre in your online account.
- Once launched, confirm your business and contact details, then select a template.
- Select Edit. Now simply add your text, required images and logo using the menu on the left-hand side. When you select an element on the page, the menu on the right side will open up allowing you to further tweak your design.
- The 'drag-and-drop' editor has all the powerful options necessary to customise your website: add images, add new pages, edit your text and build an effective online presence for your business - you can even add a map to your contact page.
- Simply click on an element to customise, for example clicking on the text allows you to modify your content.
- Select Preview to view your online presence on desktop, tablet and mobile screens without publishing.
- Once you're satisfied with the design, you can click on Publish and the site will immediately go live.
