Improving your search engine ranking position is an activity which needs continual attention and focus. We've put together the Practical SEO for Free guide which contains some of the best practice hints and tips to help you improve your search engine ranking position.
How do I register my website with search engines and improve my ranking?
You can submit your web site address to search engines so they pick up the site quickly.
See our Practical SEO for Free guide on how to submit an URL.
How long does it take for my website to appear in the search engines?
There is no set timescale for how quickly search engines rank your web site. It largely depends on how well your web site is optimised for SEO (search engine optimisation) purposes.
Please see our Practical SEO for Free guide for more information.
Why can't I find my website in search engines for specific keywords?
You can add keywords or metadata to your web site so search engines can index it more efficiently. If you're using a BT web creator tool like the Online Presence Builder or Easy Site Wizard Pro, you can easily add metadata to ensure the most appropriate keywords are used.
How can I boost website traffic and generate more business?
How do I change how my website appears on search results?
Try to keep your web site content fresh and dynamic so search engines keep indexing it. Consider adding a blog and changing up the content and images too.
