Skip to main content
BT Autobalance | Billing analytics tools | BT Business
not-authored-help-and-support
BT Autobalance
BT Autobalance is a web-based tool, that can link to your payroll system, which allows you to split out business and personal mobile calls and to then reclaim the cost of the personal calls from your employees.
Your employees receive a monthly email telling them that their personal bill is available online with BT Autobalance. They check it and tag the calls or services that you won't pay for (personal and international calls, texts, and personal data). You can even categorise part of their line rental as personal.
Your payroll system can then automatically deduct the costs from their salary.
Save money
  • Not only can you recover personal costs from your employees, you can also do it with very little effort and expense (because you don't have to do any of that laborious work identifying calls and manually calculating liabilities).
  • You save money, for sure. But so can your employees as they can make personal calls at low business rates.
Insight
The online dashboard you get with BT Autobalance gives you a clear, accurate, and timely overview of your organisation’s mobile calls bill. You'll be able to see:
  • Cost summary: including total cost of calls, recurring and non-recurring costs, VAT costs, total number and duration of calls made, as well as the number of phones contained in the bill.
  • Trend analysis: see your mobile spend as a graph.
  • Watch-points: you can monitor specific phones and numbers (and compare costs with previous bills).
Accurate VAT recovery
  • HMRC have strict rules around not claiming VAT back on personal calls made from business mobiles (penalties for breaking the rules can extend to a £1 million fine - ouch).
  • Because BT Autobalance is completely accurate, you can be confident that your VAT claims are within the rules.
Convenience
  • If employees can use their business mobiles for personal calls, safe in the knowledge that you're not just happy with it, you're giving them lower call charges than if they were using their own phones, then they only need to carry one phone around with them.
For more information about how BT Autobalance can help your business, Email us now.
Did this help?
Additional support
