We no longer support the BT Versatility and BT Quantum phone systems. We stopped selling them, and support ended on 30 September 2025.
However, help is still available if you need it. We’ve moved our BT Versatility and BT Quantum help pages to the BT Business Community, where they’ll stay available. We won’t update them if anything changes with the products, but you may still get the answers you need from the BT Business Community.
Find your phone system below and view all the relevant help and user guides.
BT Versatility
Find help with your BT Versatility system
All our BT Versatility help is in one place in the BT Business Community. See all BT Versatility posts.
The posts cover:
BT Versatility: system programming
BT Versatility: voicemail
BT Versatility: incoming calls and ringing problems
BT Versatility: Auto Attendant and greetings
BT Versatility: ring groups and DDI numbers
BT Versatility: diverting calls externally and presenting a different number
BT Versatility: user guides
Download your BT Versatility user guides
All our BT Versatility guides and manuals are in the BT Versatility: user guides post, for your easy reference.
BT Quantum
Find help with your BT Quantum system
All our BT Quantum help is in one place in the BT Business Community. See all BT Quantum posts.
The posts cover:
BT Quantum: system programming and the web interface
BT Quantum: voicemail
BT Quantum: diverting calls
BT Quantum: ring groups, hunt groups and incoming ringing
BT Quantum: Auto Attendant greetings
BT Quantum: conference calls
BT Quantum: user guides
Download your BT Quantum user guides
All our BT Quantum guides and manuals are in the BT Quantum: user guides post, for your easy reference.
Looking for a replacement?
If you’d like a replacement system, check out our cloud-based phone systems.
They’re fully supported, and because they’re cloud-based, your team can take calls from the office, from home, or on the move.
