Skip to main content
Managing your data with BT Business Mobile | BT Business
not-authored-help-and-support
How do I configure my BT Business Mobile APN settings?
APN stands for Access Point Name. It's a gateway between your mobile network and usually the public internet. The APN must match authorisation settings. These settings come pre-configured, but if you need to manually configure the BT Business Mobile APN settings, use the following:
  • APN address: btmobile.bt.com
  • Username: bt
  • Password: bt
How do I configure my BT Business Mobile MMS settings?
MMS stands for multi-media messaging service, and is a standard way to send multi-media content to and from mobile devices.
If you're having trouble sending and receiving MMS picture messages, you may need to set up your MMS settings.They should come pre-set, but if not simply use the settings below for BT Business Mobile:
  • APN address: MMS.BT.COM
  • Username: bt
  • Password: bt
  • MMSC address: http://MMS/
  • MMS Proxy: 149.254.201.135
  • Port: 8080
Can I add more data allowance or a roaming data allowance to my mobile plan?
We now offer a range of data mobile extras for customers who have high data usage or who are travelling outside of the UK. For more information see our mobile data extras online.
Did this help?
Additional support
