Skip to main content
How to check your BT Mobile Hotspot data usage | BT Business
not-authored-help-and-support
The data counter is only a guide and may differ from the network. To check:
  1. Connect to your PC via USB or wi-fi
  2. In your web browser address bar, i.e. Internet Explorer, type in http://192.168.0.1
  3. This will take you to the BT Mobile Hotspot interface (or GUI) where you can make changes
  4. The default password is admin (all lower case)
  5. Data used is shown on the home screen as Current Flux & Total Flux
  6. Select Status to see more detail
Note:
  • Both uploaded and downloaded data count against the data bundle
  • Clearing the counters resets them
  • Data usage is approximate. For actual usage refer to your network operator
Did this help?
Additional support
