Skip to main content
eSIM on Google Pixel | BT Business
not-authored-help-and-support
How do I set up an eSIM on my Google Pixel?
You’ll receive an eSIM pack with a QR code. When you have this, make sure you’re connected to wi-fi and:
  1. Go to Settings
  2. Go to Network & Internet
  3. Select the + next to Mobile Network
  4. Select Download a SIM instead?
  5. Click Next
  6. Scan the QR code with your Google Pixel camera
Can’t scan the QR code with your Google Pixel?
Don’t panic, you can manually add the information if you can’t scan it. You’ll need the 32 digit Activation Code which is on your eSIM Voucher.
When the Add mobile plan screen is open, select Add using activation code.
The activation code is a single sequence of: LPA:1$bt.pr.go-esim.com$ and the unique 32-digit activation code found on your eSIM pack, followed by $.
So, if your activation code is ABCDEF1234567890ABCDEF1234567890, you’d need to enter:
LPA:1$bt.pr.go-esim.com$ABCDEF1234567890ABCDEF1234567890$
How do I switch between SIMs on my Google Pixel?
This is easily done, on your Google Pixel go to Settings > Mobile network > Operator
And now select the SIM you want to use.
Did this help?
Additional support
