How do I set my eSIM on my Apple iPhone?
First make sure you’re connected to wi-fi. Then, when you receive your eSIM pack from us find the QR code and:
- Go to Settings
- Go to Mobile Data
- Select Add Data Plan
- Scan the QR code with your device’s camera
- Hit the Add Data Plan button
When you set up your eSIM, you can choose to name and label each line so it’s easy to see who’s calling. You can also choose which plans are used as the default for data and voice. It’s easy to change these, go to Settings > Mobile Data > Default Voice Line/Mobile Data
How do I set my eSIM on my Apple iPad?
First make sure you’re connected to wi-fi. Then, when you receive your eSIM pack from us, find the QR code and:
- Go to Settings
- Select Mobile Data
- Select Other
- Press the Add Data Plan button
Can’t scan the QR code with your Apple device?
Don't panic, you can manually enter your plan information:
- Go to Settings
- Go to Mobile Data
- Select Enter Details Manually
- Where it asks for the SM-DP+ address, enter pr.go-esim.com
- Enter your activation code (this is printed below the QR code on your eSIM pack)
- Leave the confirmation code field blank
How do I know which line my calls are on?
Contacts
When you first set up your eSIM, all your contacts are assigned to the line you chose as your default voice line. Each contact has an indicator, and you can change which line you use for that contact.
Calling a number that’s not in your contacts
If you're calling someone who’s not in your contacts, you can pick which line you call that number from the on-screen options.
Incoming calls
For incoming calls, there’s an indicator showing which line you're receiving the call on. The indicator is the first letter of the name you assigned to each line. So, if you called your lines Personal and Work, the call indicator would be a P or a W.
Can I use iMessage and FaceTime on both lines?
If you're using iOS 13 or later, yes you can use iMessage and Facetime on both lines. Just go to Settings > Messages > Send & Receive.
Can I use data when I'm on a call?
If you're taking a call on the line that isn't your default data line, data won't work unless you turn on Mobile Data Switching. When it’s on it’ll automatically switch lines for mobile data when you're on a call. To turn it on, go to Settings > Messages > Mobile Data Switching.
