Skip to main content
Where can I find my BT One Phone call log? | BT Business
not-authored-help-and-support
You can find your call log in the BT One Phone Portal. Click on Call Settings and then My Settings in the menu bar and choose the Call log option.
Or go to My Status in your Call Settings menu bar where you'll see your 5 most recent calls and an overview of voicemail messages and faxes.
If you've installed the BT One Phone mobile app, your last 3 calls are listed in the My Status function.
Important: BT One Phone is no longer available to new customers. If you're an existing BT One Phone customer, you can continue using the service while we support you through its closure. If you're looking for a new communications solution, explore our BT Business Mobile and BT Digital Voice for Business options.
Did this help?
Additional support
