APN settings (which stands for Access Point Name settings) contain information that's needed to make data connections through your phone — especially internet browsing.
In most cases, BT One Phone APN settings and MMS (picture) settings are automatically set up in your phone, so you can use mobile data straight away.
If you need to update or check your APN settings for BT One Phone, go to your settings menu and find your APN menu – often in the mobile network settings section.
APN settings for BT One Phone:
| Configuration option | Configuration information |
| APN | EVERYWHERE |
| APN type | Default |
MMS settings for BT One Phone:
| Configuration option | MMS Configuration information |
| APN | eezone |
| MMSC | http://mms/ |
| MMS proxy | MMS proxy 149.254.201.135 |
| MMS port | 8080 |
| APN type | MMS |
For more information, please refer to your phone's user guide.
