Skip to main content
Optical Network Terminator (ONT) | BT Business
not-authored-help-and-support
If you have our Fibre to the Premises (FTTP) business broadband, you’ll have an Openreach ONT (Optical Network Terminator), also known as an Openreach modem.
Your ONT needs to stay fixed to the wall or skirting as the thin green fibre optic cable can be delicate. Please be careful when cleaning around it and make sure everyone knows not to tamper with it.
Keep the plug connected in the mains whenever people will need to connect to broadband, unplugging it will cut off broadband immediately. Normal speeds will resume in a few minutes when you insert the plug again.
Why do you need an ONT?
You need a separate ONT because it takes the signals and data from the fibre optic cable and converts them into a form which your Fibre Hub can use to deliver superfast broadband around your premises. In turn, your Fibre Hub talks to devices like your computer.
Using the reset button
The reset button lets you power cycle the modem without disconnecting the power cable. You should only use it if you've contacted us and we've asked you to do it.
WARNING - pressing for 10 seconds or more will return the device to factory settings and could render your broadband service unusable.
The BBU port
The BBU port is on the back of your ONT and it stands for Battery Back-Up. This port isn’t active at the moment, so you shouldn’t plug anything into it. We might activate it in the future.
The Tel 1 & 2 sockets and light
These aren’t active at the moment, so you shouldn’t plug anything into the sockets. We might activate them in the future.
What do the lights mean on my ONT?
Here’s a handy guide to what the lights mean.
Power light
LOS light
PON light
LAN light
What this means
Green
Off
Green
Flashing green
Everything’s normal. Your ONT is working, your hub is connected, and you’re online.
Green
Off
Flashing green
Off
Your ONT is connecting. You’ll see this when your FTTP sets up.
Green
Off
Green
Off
Your ONT is working, but can’t connect to a hub.
Green
Off
Off
Green
Your hub is connected to the ONT.
Green
Off
Off
Flashing green
Your hub is connected to the ONT and traffic is flowing between the two.
Green
Off
Off
Off
Either your hub isn’t connected to the ONT or there’s a fault with the FTTP service.
Green
Red
Off
Off
There’s a fault with the FTTP service.
Off
Off
Off
Off
There’s no power to your ONT.
Having problems connecting? Disconnect the power cables to both your ONT and hub/router for two minutes. Now reconnect them. The lights should settle within a few minutes.
For help fixing problems with your ONT, go to Troubleshooting the Optical Network Terminator (ONT).
Did this help?
Additional support
