From the Hub Manager home page, click the My Devices tile.
You'll see a map showing the devices connected to your Hub and:
- The port or wireless band that the device is connected on
- The device name
- MAC address of the device
- IP address the device is using
- Data that has been transferred to and from the device (download and upload usage)
If the device is connected, the icon will be green; if it's disconnected, it'll be grey.
