Wireless
To connect to your Hub wirelessly, you’ll need the Hub’s wireless network name and password. They’re on the back of the Hub.
The Hub’s wireless name will be something like BTHub6-ABCD.
- Select your Hub’s wireless network name from the list of network connections shown on the device that you want to connect.
- Enter the password when prompted.
Or, if your device supports WPS, you can just press the WPS button on your Hub to connect without using a password.
Wired
If your device has an Ethernet port, you can use the Ethernet cable (yellow ends) instead of wireless.
- Plug it into one of the four yellow Ethernet ports on the back of your hub.
- Connect the other end to the Ethernet port on your device.
