If you want to enable remote access to devices connected to your wi-fi network, you can open all ports, or selected ports on the BT Business Hub 5 and Hub 3.
If you want to set up basic Port Forwarding, the process is identical for the BT Business Hub 5 and the Hub 3:
- From your web browser, open the Hub Manager at http://btbusinesshub.home
- Select Settings
- When prompted, enter the admin password and click OK
- Click Port Forwarding
- From the Game or Application drop down list, select the rule you require
- From the Device drop down list, select the device you want to access remotely
- Click Add
If the application you want to use doesn't appear in the list, you'll need to set up Advanced Port Forwarding. The steps you need to follow will vary, depending on your model of BT Business Hub.
BT Business Hub 5
- Select Settings
- Click on Advanced Settings
- Now select Firewall
- Next, go to the Manage Games and Applications drop down and choose Add a New Game or Application
- Enter Application name (this will describe the port you're adding, and will also be used to name the port in the Game or Application drop down)
- Enter the Required Ports in the fields provided, click Add for the port required
- Click Apply once all ports have been added
- Click Back to Port Forwarding
- Select the newly created application from the Game or Application drop down list
- Select the device from the Device drop down list or select User-defined IP Address
BT Business Hub 3
- Select Settings
- Choose Port Forwarding and then Supported Applications
- Select Add a New Game or Application
- Go to Configuration
- If using defined IP, enter the appropriate IP in the box provided
- Click Add
